It is currently Sat Apr 21, 2018 6:56 am
Poll: Pye 405 Colour Tv Or Mystery Dual Standard Hybrid Tv ?
Which TV set should Till restore in readiness for the Queen's Christmas Message?
Poll ended at Wed Jan 20, 2016 12:24 am
The 405-line Pye colour set?
24
77%
The 'mystery' dual-standard colour set?
7
23%
Total votes : 31
Post by Bobhowe » Tue Jan 05, 2016 11:15 pm
Hi i would like to start a poll for which TV for Till Eulenspiegel for this years queens speech . His very special PYE 405 colour TV which is 60 years old this year ? or a mystery hybrid dual standard set ? let the forum decide
Reason: Voting option added; the poll will run for 14 days.
Re: Pye 405 Colour Tv Or Mystery Dual Standard Hybrid Tv Po
Post by marc » Tue Jan 05, 2016 11:26 pm
Hi Bob,
Well I can't think of many colour sets over here that will be celebrating a 'ruby' anniversary so based on that rather flimsy thought of mine I'll place a vote for Till's Pye 405. :)
Post by Cathovisor » Wed Jan 06, 2016 12:32 am
As you can see, I've turned the thread into a poll, so... faites vos jeux, ladies and gentlemen :qq1
Post by Wolfie » Wed Jan 06, 2016 1:41 pm
I have no idea what the question is?
Post by Terrykc » Wed Jan 06, 2016 2:41 pm
Post by Cathovisor » Wed Jan 06, 2016 3:17 pm
Wolfie wrote:I have no idea what the question is?
<facepalm>
Is this clear enough for you? It's at the top of the thread, where polls usually live.
Post by Wolfie » Wed Jan 06, 2016 8:14 pm
Ah yes, I seethat now, it's Bobs very first message that completely threw me.. and I still cant make any sense of that, I think it's the three fours.
Right, I'll go munch one of Mishka's dementure tablets, the peppermint ones.
Re: Poll: Pye 405 Colour Tv Or Mystery Dual Standard Hybrid
Post by Bobhowe » Wed Jan 06, 2016 8:55 pm
As the poll says no vote will be counted after Tuesday 19th Jan at 11.24 pm & if the vote is a tie i will have the casting vote :aaj
Post by Cathovisor » Thu Jan 07, 2016 9:51 pm
The way the poll is going I don't think there'll be any need for a casting vote...
Post by malcscott » Thu Jan 07, 2016 10:12 pm
Does this mean that the mystery set will remain in storage for another 36 years !! :bba
Post by Cathovisor » Thu Jan 07, 2016 10:42 pm
No, I was going to suggest it was ready for the New Year Concert from Vienna...
Post by malcscott » Sat Jan 09, 2016 6:25 pm
David has collected the mystery set, on his way home with it now. :bba Malc.
Post by Till Eulenspiegel » Mon Jan 11, 2016 4:08 pm
The mystery set is a dual standard hybrid and it's not a G6.
Post by Cathovisor » Mon Jan 11, 2016 4:23 pm
There's a bit of me wants it to be a Bush CTV25...
Post by Till Eulenspiegel » Mon Jan 11, 2016 6:28 pm
It's not a Bush CTV25. A clue: like the early Bush CTV25 it also uses the GY501 and PD500 stabiliser valve.
Post by ntscuser » Mon Jan 11, 2016 6:45 pm
Is it an Ekco CT102 or CT104?
Post by Till Eulenspiegel » Mon Jan 11, 2016 6:58 pm
I'll think you are so close I'll tell you the exact model. It's the Ekco CT103.
Post by ntscuser » Mon Jan 11, 2016 7:15 pm
Ah, I was misled by this article in Radio and Electrical Retailing July 1969 which claims the CT103 was a single-standard receiver:
Post by Till Eulenspiegel » Mon Jan 11, 2016 7:35 pm
I've got the model type wrong. It can't be a CT103 because you've confirmed that is the 19" model. So it's likely to be the CT101? or CT102. Does not have cabinet doors. The set has the same type of tuner as the Pye CT70, that is the one with the square buttons.
Post by ntscuser » Mon Jan 11, 2016 7:46 pm
Till Eulenspiegel wrote:I've got the model type wrong. It can't be a CT103 because you've confirmed that is the 19" model. So it's likely to be the CT101? or CT102. Does not have cabinet doors. The set has the same type of tuner as the Pye CT70, that is the one with the square buttons.
Sounds like the CT104, with green tube surround? (As far as I know there was no CT100 or CT101).
Post by Till Eulenspiegel » Mon Jan 11, 2016 9:22 pm
The CT100 was the experimental set which employed a round 21" CRT. Started off as a 405 receiver and later on modified to NTSC 625 and finally 625PAL.
Read about the CT100 and Ct101 here: http://www.vintage-radio.net/forum/show ... +colour+TV
Post by ntscuser » Tue Jan 12, 2016 12:39 am
Ah, it was considerate of Ekco's new owners to maintain the numbering sequence after such a long absence. The numbers also suggest they intended to release the 19" set much earlier than when it eventually appeared.
Post by malcscott » Tue Jan 12, 2016 1:24 am
CT102.
Post by ntscuser » Tue Jan 12, 2016 4:25 am
I thought the CT102 had doors, as per the one on Mikey 405's website?
http://www.oldtechnology.net/colour.html#ekcoct102
Post by malcscott » Tue Jan 12, 2016 9:25 am
CT104?
