It is currently Thu Jul 19, 2018 6:23 pm
1975 26" GEC 2147 : Series 2110 Chassis
Re: 1975 26" GEC 2147 : Series 2110 Chassis
Post by Till Eulenspiegel » Tue Mar 01, 2016 5:02 pm
with regard to those green capacitors it's not just the dielectric insulation resistance that comes into question but also the performance at a given frequency. As flyback tuning capacitors there will be considerable strain on the dielectric, mechanical strain in fact and that's why those capacitors get hot.
Post by crustytv » Tue Mar 01, 2016 7:38 pm
405 fan wrote:Hi Chris
Thanks I will bring them over some time . I was beginning to think that there was another fault in the set causing this but these green caps are unreliable.
Regards.
Gary.
It grates on me too when you have a bunch of NOS caps that are not fit for original purpose, but there is the clue, "Not for for original purpose".
In my opinion there is no reason to bin them, they may be perfectly fine for other use in lesser circuit positions and certainly out of the high pulse condition of the line stage. For example I had a number of NOS Philips red cans the 470uF/250VDC ones with the rivet fault that could end up causing the scary EHT blow hole in a CRT. Also I have about 500 NOS .1uF/275VDC RIFA caps and many NOS Plessey blue/whites. Rather than bin all these caps I use them all in low voltage/Low stress application, so far all has been well. Just worth keeping a note in the stock draws to remind others.
I just ordered some 5100PF 2000V Pulse MKP10 Capacitor from CHS as I don't have any in stock and I think my 2100 chassis GEC has the original cap in place. It will be interesting to see if they turn up quicker than your Cricklewoods
Post by Cathovisor » Tue Mar 01, 2016 8:36 pm
Till Eulenspiegel wrote:with regard to those green capacitors it's not just the dielectric insulation resistance that comes into question but also the performance at a given frequency. As flyback tuning capacitors there will be considerable strain on the dielectric, mechanical strain in fact and that's why those capacitors get hot.
This is why polypropylene dielectric caps are used in flyback tuning. Polypropylene has superior performance when dealing with very fast rise/fall times, and also with the inevitable high current that flows - I = C(dv/dt) an' all that. Polyester is only suitable for decoupling or the slow rate of change of audio.
Post by EDDINNING » Tue Mar 01, 2016 9:19 pm
Hi Gary, it may be water ingress if they are not correctly sealed. or they may not be up to the job of fast rising pulses.
You could try connecting 2 caps in series and another 2 series ones in parallel. This should give the same value but less stress on each cap.
Note that running the set with defective caps could effect other components.
Post by Till Eulenspiegel » Tue Mar 01, 2016 10:24 pm
In the 1970s those green Philips flyback capacitors had a dreadful reputation. The original Thorn 8000 series CTV employed one in the line output stage. It wasn't long before a replacement capacitor of a different make was supplied from the TCE service department.
It is a very rare event when bad component comes from Philips.
Post by sideband » Tue Mar 01, 2016 11:39 pm
CrustyTV wrote:It grates on me too when you have a bunch of NOS caps that are not fit for original purpose, but there is the clue, "Not for for original purpose".
In my opinion there is no reason to bin them, they may be perfectly fine for other use in lesser circuit positions and certainly out of the high pulse condition of the line stage. ]
I'll second that. I have some of these original Philips caps...all test fine on the bridge with excellent leakage characteristic. Knowing their reputation in pulse circuits, I've used them in other positions with no problems at all. One such has been used as a tone corrector across an output transformer primary for well over 10 years.
So don't bin them just because they don't like pulse circuits.
Post by colourmaster » Wed Mar 02, 2016 1:37 am
Hi Chris
I've just ordered some from CHS as well .
Regards.
Gary.
Post by sideband » Wed Mar 02, 2016 9:18 am
Till Eulenspiegel wrote:It is a very rare event when bad component comes from Philips.
True, but remember the yellow tuning caps used in the line output stage of the G11 (9n1 I think)? They used to fail by burning down one side where the lead was welded. Philips components reckoned it was poor welding after investigating and they changed the construction to the later 'box' type capacitor. No problems with those.
Post by PYE625 » Wed Mar 02, 2016 10:14 am
Well done Gary, it's a nice set with a good picture....pleased to see it went to one of us on here lol :bba
Post by crustytv » Wed Mar 02, 2016 10:57 am
Just received and e-mail from CHS, the 5.1nF pulse cap order has been canceled as they are no longer in stock, with no suitable replacement to be found. Gary, I suspect you will encounter the same. Lets hope they amend their website as that was most infuriating :bbd
Post by Cathovisor » Wed Mar 02, 2016 11:32 am
I'm concerned that Cricklewood seem to be taking as long as they are... else it's 4.7nF in parallel with 470pF time: both these values are obtainable from Farnell in radial packages at up to 2kV, btw.
Post by Rallycoordinator » Wed Mar 02, 2016 1:48 pm
Your set has certainly responded well to sympathetic restoration.
Just a hobbyist’s suggestion – would a Panasonic ECW-H20512HV capacitor be of any use as for this application?
http://www.mouser.com/ds/2/315/ABD0000CE25-36779.pdf
In the late 1970's I fixed a few minor faults (defective BT106 in power supply plus R107 on LOPT) on a later version, which overall proved to be very reliable and a nice set to work on.
Post by crustytv » Wed Mar 02, 2016 2:30 pm
Cathovisor wrote:Gary, have you tried putting some of your NOS ones on a bridge to see what value they come out as?
I found one of those green tuning caps in my stock, out of interest I put it on the bridge at 600V no leakage. Unable to do a value check, the eye is duff so unable to balance. Then onto an insulation test at 1kV dmm it seemed happy, the meter indicating a little over 50MΩ. But as we've discussed earlier hardly indicative of the real harsh working conditions, theses caps would face.
Post by Cathovisor » Wed Mar 02, 2016 3:08 pm
Given I = C(dv/dt) I wonder just how much current these caps are carrying?
Post by Till Eulenspiegel » Wed Mar 02, 2016 4:09 pm
Cathovisor wrote:Given I = C(dv/dt) I wonder just how much current these caps are carrying?
The rise time of the flyback pulse is not a true step function being in the sense of the cosine type of waveform. Nevertheless, there will be a lot of energy in that pulse when one considers first it is stepped up to 8KV to supply the EHT tripler cascade. We know the max beam current is in the order of 1mA @ 25KV. that's 25 watts!
Secondly, all that energy contributes to the first 40% of the line scan. That capacitor has a tough job to do.
Post by colourmaster » Wed Mar 02, 2016 4:45 pm
Hi Chris
I did indeed receive the same email this morning but incredibly the cricklewood ones arrived this morning. I've been at work all day today conduction a couple of friends funerals so I'll try one of these cricklewood caps tomorrow.
Regards.
Gary.
Post by colourmaster » Wed Mar 02, 2016 4:58 pm
Hi everyone
I've made a mistake, the caps that came this morning are the ones I ordered from that link that Chris found . The blue ones on ebay, do you think they'll be ok in the GEC ? . The cricklewood caps are still on their way .
Regards.
Gary
Post by Rebel Rafter » Wed Mar 02, 2016 9:16 pm
Hi, folks, RR here. I've found some exact replacements for the 5n2, just take a look on vintageparts.com, they've got some, 188 in stock at 95p each. 5%, 1500v. Sorry I don't know how to make a link but they're easy to find, just go on the site and type in 5N2 in the search box. I hope this helps. They've also got some visconol's, .001uF. RR.
Post by Refugee » Wed Mar 02, 2016 9:29 pm
On VGA CRTs with there 50Khz line scan circuits even the Phillips blue box pulse caps fail open circuit with a little black sooty spot on the end where the lead is welded on.
Those Panasonic dip types fared better though. I have got plenty of Phillips 6n2s left over from my VGA days.
Post by crustytv » Wed Mar 02, 2016 9:31 pm
Rebel Rafter wrote:Hi, folks, RR here. I've found some exact replacements for the 5n2, just take a look on vintageparts.com, they've got some, 188 in stock at 95p each. 5%, 1500v. Sorry I don't know how to make a link but they're easy to find, just go on the site and type in 5N2 in the search box. I hope this helps. They've also got some visconol's, .001uF. RR.
But they are the exact same NOS caps that Gary already has plenty of and that have been failing. http://markhindes.easywebstore.co.uk/5N ... A6WXO.aspx
The risk in purchasing those is the same, under load in the line stage could and likely will fail . Far better as we are trying to do, is to seek out a modern equivalent.
Post by sideband » Wed Mar 02, 2016 10:35 pm
I've just put a link to them in the 'suppliers' section.
Yes those caps will be unreliable in line stages. Philips were scrapping them 30 years ago...
Post by colourmaster » Wed Mar 02, 2016 11:22 pm
Hi everyone
That's where I obtained these NOS caps from so I wouldn't order anymore . I'll try the type that I had delivered today in the set and see what happens.
Regards.
Gary.
Post by colourmaster » Thu Mar 03, 2016 1:23 pm
Hi everyone,
I've fitted one of these blue ones today and so far the sets been running for nearly half an hour. The cap is cool, I thought it might have been a little warm. So that's it the restoration is complete. Thanks to everyone for your comments.
Regards.
Gary.
Post by Focus Diode » Thu Mar 03, 2016 9:59 pm
Excellent result there Gary, well done.
Probably related this but recall when adapting the HMV 2633 16" 960 portable to take a 1400 Lopt when the original red jellypot failed I fitted a NOS 180pF 8Kv disc capacitor to the transformer. 160pF would have been preferred but I didn't have one. The capacitor runs extremely hot. Still works well despite this. Haven't tried another until I can get a suitable 160pF type. These transformers can easily be ruined by heat from the iron as we know.
Post by marc » Thu Mar 03, 2016 10:37 pm
Hi Gary,
That certainly looks the part now, :aad
I feel a touch of envy coming on ! :aah
PS...Glenys says can we share it, 6 months here and 6 with you. :bba
