It is currently Wed May 23, 2018 6:09 am
1972 PYE CT205: 697 Hybrid Chassis
Post by The_Teleman » Tue May 17, 2016 10:12 am
Finally got into the the colour set collecting
Just acquired this rather nice CT205
Needs a bit of work but at least the crt is a good one
Re: 1972 PYE CT205: 697 Hybrid Chassis
Post by rob t » Tue May 17, 2016 10:26 am
A good set to start on good luck.
Post by malcscott » Tue May 17, 2016 1:09 pm
:aae :ccf :aae
Post by cobaltblue » Tue May 17, 2016 3:38 pm
Seems to be a difference of opinion about this model :aad
Mike T
Post by crustytv » Tue May 17, 2016 3:55 pm
Nice one Chris, good to have another join the colour club, slowly but surely we convert you all :aah
For you it had to be a PYE didn't it :thumb The full PYE service manual for this chassis can be found in the data library. Not forgetting the additional and superb decoder diagnostics guide, with this chassis you're going to need it :qq1
Also don't forget all the stock faults for early colour are also available from the main site top menu "stock faults", including PYE. Then there's Les Lawry-Johns article called "Hot Pyes" which is available from the menu "Service" | "CTV service tips".
Here's what it looked like new in 1972....... you want to keep any eye out for a stand now, unless it came with one.
Post by PYE625 » Tue May 17, 2016 5:44 pm
The_Teleman wrote:Finally got into the the colour set collecting
Well done !!
I happen to like the styling, a nice set I wouldn't say no to.
Post by Tazman1966 » Wed May 18, 2016 9:32 am
Nice that the veneer hasn't chipped off the front either. With a bit of care and careful setting up, the fact that the CRT's a good 'un means you'll get good performance out of it.
Good luck,
Tas
Post by The_Teleman » Sat May 21, 2016 12:26 pm
Had to take a look inside the curiosity was getting the better of me
The set looks tidy for its age , the cda panel looks ok no sign of burning
The timebase panel looks ok too but someone has removed one of the edge connectors
& soldered the wires to the board
Don't know if I can get an edge connector to replace it , it may have to stay as it is
The set date stamp on this one is Feb 1974 so I presume this is a later set
Didn't the 725 series come out in 1975 ish?
All in all looks good , can't wait to get started but have another PYE on the go 170 series
Post by malcscott » Sat May 21, 2016 12:30 pm
At least it has the best type crt fitted. Mullard red label, Malc.
