It is currently Sat Jul 21, 2018 8:04 pm
Homebrew valve tester
Post by Dr Wobble » Tue Apr 07, 2015 9:58 am
Someone kindly gave me a heavy metal box some time last year and have finally got round to building a simple valve tester. It has two HT PSU's using a IRF740 mosfet 0 - 300v, a heater supply switched between 5,6.3,12.6 and adjustable @ 2.5A at a push using a LM317AVH. I've used whatever bits I had apart from the two big pots I got from Birkitts to adjust the HT, at £2.50 each I'm well happy. Sere pic.
For testing rectifiers I'll put the VT on my isolated variable supply for the ac and I've wound a few turns round an existing transformer to give me 5v @ 3A ac.
As you see I've used a jumper panel to switch anode, cathode etc between pins. The amp meter can read either up to 20mA or 100mA, I prefer digital meters but as I had the old panel meters, I used them. I have another HT PSU to make amd some wiring up of the front panel but that's about it. If I get time I will wind a proper transformer, but it will do the job for now.
Andy.
Big 10k 70mA pots from Birkitts.
HT and Heater PSU
Front panel minus screen meter and heater meter-in post.
Re: Homebrew valve tester
Post by EDDINNING » Tue Apr 07, 2015 9:10 pm
Hi Andy, looking at you layout, you may need to beware of the rather long leads to the regulators, as this may cause oscillation and instability.
Post by Dr Wobble » Wed Apr 08, 2015 8:51 am
Do you mean the two TO220's? They are TIP3055's there to boost the current.; it's not the best layout for sure, but havn't had a problem with similar in the past. I know a few people had problems with oscillation on the Sussex and had to put ferrite beads on the leads.
The heater board got filled with caps as I had to use 4 1000u 50v leaving no room for the power transistors, as I had no big 63v caps. The sec winding off the tfmr is 58v.
Andy.
