It is currently Sat Jul 21, 2018 8:17 pm
Polar T1500 Fault Locator.
Post by Doz » Thu May 14, 2015 10:10 pm
You just connect it to the circuit and it says C103 leaky & R 45 High resistance .....
if only :aaj
This was given to me, arrived with the mains lead cut off, and a fault in the voltage multiplier.
Seems to be an interesting instrument.
Pictured here with a diode across A & Com and then reversed.
Re: Polar T1500 Fault Locator.
Post by Marconi_MPT4 » Fri May 15, 2015 5:31 pm
Another piece of test gear saved from obscurity and brought back to life. Looks good.
Some time ago I found a Huntron Tracker 2000 in a WEEE skip and despite being dropped in there, only suffered from a few scrapes. Thread here http://www.forum.radios-tv.co.uk/viewtopic.php?t=5015&p=52949#p52949.
Tests with an EHT transformer overwind illustrates the difference between normal operation and one shorted turn.
Post by Doz » Sat May 16, 2015 12:48 pm
I've tried testing a lopt with it, doesn't seem to get any perceptible change.... then again I might not be doing it right. :cch
Post by Alistair D » Sat May 16, 2015 1:58 pm
Just looked at Polar's website, £50 for an e copy of the manual. Ouch!
I have a Polar T550 toneohm here. I did find a manual for that online so I as hoping to find the site in case it had the manual for yours. No luck.
