It is currently Sat May 26, 2018 1:09 pm
Faulty Philips PM 5508 Pattern Generator
Re: Faulty Philips PM 5508 Pattern Generator
Post by Refugee » Mon Oct 05, 2015 10:44 pm
I would have a good look at the power supply before going any further as the video looks like it has got ripple on it.
Post by marc » Mon Oct 05, 2015 10:49 pm
Refugee wrote:I would have a good look at the power supply before going any further as the video looks like it has got ripple on it.
Hi Simon,
When used with 'video out' all patterns work and are rock steady so if the PSU was playing up wouldn't I get issues on both RF and video out ? :aaq
Post by Refugee » Mon Oct 05, 2015 11:07 pm
The RF part of the unit may well be on a different output from the power supply.
The power to the logic sections is clearly all right though.
Post by marc » Mon Oct 05, 2015 11:17 pm
Refugee wrote:The RF part of the unit may well be on a different output from the power supply.
It has a single output PSU of +6v 0 -6v supplying all boards so I guess that means the PSU is unlikely to be at fault (famous last words) :qq1
Post by Refugee » Mon Oct 05, 2015 11:36 pm
marc wrote:
TVJON74 wrote:Hi Marc,
Are the dial bulb working OK? The UHF side should be lit when a UHF pre set is being used and the VHF side should be lit when a VHF pre set is being used. The +6V supply is switched between the UHF & VHF modulators and the corresponding dial bulb.
Check the +/-6V supplies are getting to the modulators.
Hi Jon,
Yes the bulb and modulator supply is switching correctly between the two.
However there is only +4.2v and -5.97v at the UHF modulator
VHF modulator is +5.69v and -5.97v
This post is the one that is making me suspect the power supply.
That +4.2 volts is a red warning to me being almost 30% down on the 6V it should be.
Surely that is enough for a full power supply examination.
It could be bad switching or decoupling.
Post by marc » Mon Oct 05, 2015 11:45 pm
Yep that's bugging me too.
The drop only occurs when the UHF mod is switched into play, when the VHF mod is on the voltages come back up so I reckon it's time to crack open the UHF mod :aaq
Post by TVJON74 » Mon Oct 05, 2015 11:49 pm
Hi Jon,
There is a series inductor and a cap to ground on the +&- 6v rails feeding the modulators. Those supplies are used for both VHF & UHF. Only the +ve rail is switched.
Post by marc » Tue Oct 06, 2015 12:00 am
the voltage drop when the UHF mod is switched in was caused by it's panel bulb, once removed the voltage is back up to 5.97 from 4.2
I can now see a very grainy chequer board on UHF 625 but still a way to go.
At last something on 625 UHF
Post by Cathovisor » Tue Oct 06, 2015 12:08 am
marc wrote:Hi all,
Errrr... shouldn't those power supplies be regulated? :aab
Post by Refugee » Tue Oct 06, 2015 12:14 am
Can you tack in a modulator from an old video recorder to see if that fixes it?
Post by marc » Tue Oct 06, 2015 12:23 am
As if by magic.....
UHF 625
Even cross hatch works
Don't ask me how but up it's come. :aab
All I have done is remove the UHF panel bulb.
Next thing is try it on a colour set to see if the rest works.
Post by marc » Tue Oct 06, 2015 1:41 pm
After trying the generator on a colour set it's fairly obvious that the out going RF signal is pretty weak. All patterns and colours are there but quite snowy.
Another look at the internal coax's is on the cards I think.
Post by Refugee » Tue Oct 06, 2015 1:54 pm
It may be worth having a look at the output transistor in the modulator.
If it is faulty it would account for the modulator dragging the voltage down.
Post by marc » Tue Oct 06, 2015 2:27 pm
Refugee wrote:It may be worth having a look at the output transistor in the modulator.
Hi Simon,
I'll do that but as for voltage's there fine since the UHF modulator scale bulb (wrong type) was removed.
Post by Refugee » Tue Oct 06, 2015 2:53 pm
Have you tried swapping the bulbs over?
Post by Alistair D » Tue Oct 06, 2015 3:09 pm
Have you tried scanning the TV across the whole band just in case you are tuned to a spurious output?
Post by marc » Tue Oct 06, 2015 3:28 pm
Hi Simon,
Yep I've tried bulb swapping and the voltage drop moves with the duff bulb to which ever modulator it's connected to so has now been removed and the good bulb is on the UHF modulator.
Hi Al,
I've swept the entire band on both the generator and TV but the signal from the generator remains weak at all points.
