It is currently Tue Jul 17, 2018 7:08 am
Paint to give Bakelite finish?
Post by davegsm82 » Tue May 21, 2013 5:25 pm
I'm busy making a cabinet for a little project, I'd like it to have a nice bakelite finish, similar to a DAC90 if possible, however this will be on sanded down MDF.
Any suggestions?
Re: Paint to give Bakelite finish?
Post by Briancuff » Tue May 21, 2013 5:50 pm
I've never tried it but I seen a description of a method using several different shades of brown paint. Spray on thin coats of the different colours, letting them dry thoroughly between each coat, even spraying the same colour twice, with a different colour between them, and then, using very fine wet & dry (eg 1200 grit) rub away the upper layers in a random fashion. This gives the marbling effect of Bakelite.
Post by davegsm82 » Wed May 29, 2013 1:39 pm
Hi Brian,
Thank you for your advice, although I was wondering, what kind of paint should I use?
I'm a complete novice so really, paint could mean anything from Automotive spray to garden gate hammerite!
I have some MDF to experiment on before letting loose on my 'creation' :=D
I hope that whatever paint I use will sort of 'leech' into the MDF, as unfortunately there is some fairly fine detail on my piece and it appears that it is easily damaged, a simple knock can take off a whole chunk.
Post by Briancuff » Wed May 29, 2013 1:59 pm
I would try acrylic paint, Dave. There is a huge range of colours to play with. The leaching into the MDF is an advantage because you have then a background colour to work down to. However, I would have thought that if your project is complicated, it will be quite difficult to use wet & dry on it!
Post by davegsm82 » Thu May 30, 2013 7:55 am
Would that be Acrylic Spray paint or something like artists paint?
As for getting the paint into the MDF, i hope it does this to provide a little mechanical strength, I've even considered giving the whole thing a thin coat of watered down PVA glue, however i'm not sure how well the paint would take to this.
Post by crustytv » Thu May 30, 2013 8:07 am
I've repaired Bakelite and as Brian has said used Acrylic paints to match the finish. As example here is the classic chip on a Bush DAC90A, just below the dial (see below). I used a combination of browns and terracotta mixes.
I would imagine a similar combination would yield the result you require but on a larger scale.
Good luck look forward to seeing the results.
Post by Briancuff » Thu May 30, 2013 8:38 am
The spray cans are ideal for large areas but for fine touching-up, that artists' type is good. Till uses the latter to create grain figuring on veneers he has applied in order to match existing bits - see the thread on the wreck of a pre-war HMV 900 set from NVFC here:
viewtopic.php?f=5&t=3531&p=37221&hilit=900#p37221
