It is currently Sat May 26, 2018 1:05 pm
BRC 2000 Tripler Rebuild
Re: Silicone Potting Compound/ BRC 2000 Tripler Repair
Post by crustytv » Fri Dec 19, 2014 12:51 am
Hi Rich
I certainly did, however a couple of bubbles still appeared, to remove I jarred the unit on the bench, they sunk. I then topped the area up with more potting.
I think its OK, well fingers crossed its the first tripler rebuild I've attempted.
Its now dry enough to trim which I have just done. Now put to one side for a couple of days for it to fully cure throughout.
Post by crustytv » Fri Dec 19, 2014 1:52 am
The diodes should be fine.
If you read Tony's previous post he stated the ones he supplied me, are the ones used in 3000/3500 triplers. BRC 3000/3500 triplers are virtually identical and use the same number of sticks as the 2000 (5).
Post by crustytv » Sun Dec 21, 2014 5:39 pm
After 60hrs of curing I couldn't wait any longer as the suspense was killing me. This afternoon I tested the rebuilt tripler in the Ferguson 3700, happy to report its a complete success :thumb
Post by Cathovisor » Sun Dec 21, 2014 6:03 pm
:aan
Post by Valvebloke » Sun Dec 21, 2014 8:24 pm
Isn't it nice when things just work ... https://www.youtube.com/watch?v=_ve4M4UsJQo :bba ?
VB
Post by marc » Sun Dec 21, 2014 8:42 pm
Valvebloke wrote:Isn't it nice when things just work ... https://www.youtube.com/watch?v=_ve4M4UsJQo :bba ?
VB
Maybe VB has come up with Chris's next challenge after all we all no how good he is building sets from bits so how about a "Honda style TV parts ad" as a challenge ? :qq1
Post by turretslug » Mon Dec 22, 2014 8:55 pm
Excellent result there- looks as though my pessimism over leaving it unpotted for testing was decidedly misplaced! :aad That compound looks very much like the stuff that Schaffner mains filters are drenched in- has it set hard or soft? The Schaffner stuff sets pretty hard, making it difficult (though not impossible) to dig out for changing Rifas...
Post by crustytv » Mon Dec 22, 2014 9:01 pm
turretslug wrote:That compound looks very much like the stuff that Schaffner mains filters are drenched in- has it set hard or soft?
Soft, so if I ever need to repeat the rebuild, it will be a simple dig out once again.
I have one other to rebuild, however that needs a VDR and I've yet to find a replacement or figure our a substitute.
Edit: Article now written up for the main site http://www.radios-tv.co.uk/?page_id=887
Post by Tony » Mon Dec 22, 2014 9:48 pm
This may sound silly but once you've finished with the tin of silicone, seal it in a couple of thick bags and put it in the freezer.
The catalyst can be kept elsewhere as it lasts for a while but the low temperature will prevent the rubber self-condensing and should at least double the shelf life.
