Ekco AD75 dial reproduction
PostPosted: Sun Apr 10, 2016 3:33 pm
by kalee99
Hi All,
I am on with my next Ekco round one. The scale was almost worn away as these sets seem to have no dial cover glass?
So I have made a new dial on Photoshop.
Can only put a low res' image on here but if anyone wants a high quialty jpeg then just PM me with your email address & I wlll send it you.
Paul.
Re: Ekco AD75 dial reproduction
PostPosted: Sun Apr 10, 2016 4:36 pm
by Cathovisor
Did you mean to type 'Welch' ?
PostPosted: Sun Apr 10, 2016 4:55 pm
by kalee99
Well spotted,
I also missed some graphics off (senior moment).
Paul.
PostPosted: Sun Apr 10, 2016 11:09 pm
by Katie Bush
Ironically, in the dim and distant past, "Welch" would have been acceptable, if not even the preferred spelling (though probably before radio!).
PostPosted: Mon Apr 11, 2016 6:23 pm
by Terrykc
kalee99 wrote:Can only put a low res' image on here but if anyone wants a high quialty jpeg then just PM me with your email address & I wlll send it you.
A pity that it has been saved as a .jpg. If it had been kept as a .png and the slight pinkish sheen removed, I would expect the original file would have been quite small.
Unfortunately, once it has been saved as a .jpg, there is no going back.
As I've said here very many times, the p in jpg stands for picture and that is what the format is designed for - pretty pictures. It is also a lossy form of compression, so the original quality is lost.
However, the g in png stands for graphic, which is what this is, added to which it uses lossless compression, so you always preserve the quality.
PostPosted: Mon Apr 11, 2016 10:13 pm
by kalee99
The dial was created on a Mac using photoshop and the photoshop file is still here. Unfortunately it is to big to display on here. No "pinkish tinge", on the photoshop file its not a background colour I would use.
I just put it on here as a jpeg as its easy. Other formats are available :aad
Paul.
PostPosted: Tue Apr 12, 2016 2:39 pm
by Terrykc
In which case, Paul, if neither the MAC or Photoshop* have used a lossy compression method to save the file at any time, a direct conversion to .png should result in quite a small file.
* My concern is that, being a program specifically aimed at pictures, it will use a file format more appropriate to pictures rather than graphics. However, my wife uses Photoshop Elements and says that files saved in its own proprietary formats are still a 'humongous' size, it sounds hopeful.
Give .png conversion a try - you might be pleasantly surprised!
PostPosted: Tue Apr 12, 2016 5:25 pm
by kalee99
Hi Terry,
Yes the photoshop on Mac gives lots of "save as", options including png.
So saving as a png it gives me the option of various file sizes (compression).
This is the biggest one I can put on here. The quality is ok but not as good as the actual photoshop file. In the past I used to have Aldus freehand but the licence on it expired and I am not willing to pay several hundred £ for a renewal + updates :bbd
So I just manage with photoshop.
It is still showing a pinkish tinge which is not on the photoshop file or the actual printout. I will have to look for a bootleg copy of Aldus.
Paul.
PostPosted: Wed Apr 20, 2016 11:29 am
by Terrykc
That's looking good, Paul, and only 163KB!
Have you thought of putting your large file in Dropbox (or something similar? and linking to it, with a thumbnail to show what it is? That way you get the best of both worlds!
kalee99 wrote:It is still showing a pinkish tinge which is not on the photoshop file or the actual printout.
How very strange - I can't detect the tinge on this copy!
I even selected a large area and deleted it, expecting the boundary between the white and pink to give itself away but nothing!
