It is currently Sat May 26, 2018 5:17 am
Blown Ceramic Fuses
Blown Ceramic Fuses
Post by valvekits » Fri Mar 29, 2013 10:31 pm
Something I found out today, those old/blown ceramic fuses that none of us would ever save, make good stand offs. 4BA screw is a perfect fit.
Eddie
Re: Blown Ceramic Fuses
Post by Refugee » Fri Mar 29, 2013 10:40 pm
Does the part you are fitting onto the chassis still fit if one of the standoffs is rated at 3 or 5 amps?
Post by valvekits » Fri Mar 29, 2013 10:43 pm
I don't know but I have got a big bag of 13A fuses. :D
Eddie
Post by Refugee » Fri Mar 29, 2013 10:57 pm
Last time I took one apart it was the end caps I wanted so the ceramic tube had to go.
You can only save one or other of the parts.
As I use old plugs again including the molded type if there is enough cable still there I often have to replace the fuse with the correct type and also have a drawer full of 13A type fuses that are still OK.
I had to buy packs of 3A and 5A not so long ago :(
