It is currently Sun Aug 19, 2018 6:28 am
bag of bits
bag of bits
Post by crackle » Tue Mar 03, 2015 12:15 pm
I bought a bag of components from the bring and buy stall at Harpenden.
There were some interesting components that I have not come across before.
Here are a few.
I thought it unusual to see small diodes in a metal can, open at one end. The body is about 5mm long. I cant find any reference to the CV number, it must be highly top secret.
The black resistor is 499k (light reflection makes it look like 429) obviously 500k was not precise enough for the circuit designers, it should be useful for checking the high ranges of my DMM, and the pink resistor should be useful for checking the low ranges.
This object which looks like a multi tap power resistor has me puzzled. What is it and how do those measurements work out :bbd
I originally thought this was just a glass tube, then I noticed it does appear to have something inside it. You can just see the tiny little bead just under the second T in "Thermistor" and the almost invisible wires coming from each side of the bead. There are no external connections outside of the glass tube so I am assuming the glass tube is just protective packaging and would be broken to remove the thermistor from the inside. As a scale the glass tube is about 3mm diameter.
Oh, and these cup things which look like some sort of ceramic, what are they? They fit nicely on the tips of my fingers and are good at annoying every one if I drum my fingers on the desk. :bba . The writing on it looks like LECO 12 and then repeated on the other side.
Re: bag of bits
Post by Boater Sam » Tue Mar 03, 2015 1:06 pm
What is on the ends of the glass tube? Looks like the thermal cut outs used on ceramic hobs. The glass expands when hot, the invar wire inside doesn't, the switch went on the end.
Ceramic things, crucibles?
Re: bag of bits
Post by crackle » Tue Mar 03, 2015 1:42 pm
Boater Sam wrote:What is on the ends of the glass tube? Looks like the thermal cut outs used on ceramic hobs. The glass expands when hot, the invar wire inside doesn't, the switch went on the end.
The ends of the glass tube are sealed, it looks like the ultra thin wavy wire inside the tube stops short of the ends.
Re: bag of bits
ppppenguin wrote:Fairly sure the CV diode is a zener. Power supply, resistor and meter should confirm that.
Ill give that a check.
mike
Re: bag of bits
Post by Briancuff » Tue Mar 03, 2015 2:56 pm
The thermistor looks like a fast acting thermistor for use in feedback loops. The original Mullard transistor audio oscillator used an R36? in a feedback loop to control the output level. It is in vaccuo so that ambient temperature has little effect on it, only the current through it.
Re: bag of bits
Post by Valvebloke » Tue Mar 03, 2015 3:19 pm
Crackle wrote:... This object which looks like a multi tap power resistor has me puzzled. What is it and how do those measurements work out :bbd
I'd be very, very careful with this. It appears to be the property of The Mysterons :ccf .
EDIT: I think the measurements are explained by it not actually being multi-tapped. Instead it consists of four separate resistors, each having one end connected to the centre wire (wire number 3 if you number them 1, 2, 3, 4, 5 from left to right). So 1-3 is 150, 2-3 is 514, 4-3 is 381 and 5-3 is 891. All the other measurements are made up, as near as d@mm!t, by adding these up. So 1-2 is 1-3 + 3-2.
VB
Re: bag of bits
Post by crackle » Tue Mar 03, 2015 3:55 pm
And today's star prize goes to VB, well done, you have cracked it. The odd inaccuracies must be my meter readings and dirty wires.
What a weird contraption, and strange way of packaging 4 resistors wired to a common point.
Re: bag of bits
Post by crackle » Tue Mar 03, 2015 4:12 pm
Brianc wrote:The thermistor looks like a fast acting thermistor for use in feedback loops. The original Mullard transistor audio oscillator used an R36? in a feedback loop to control the output level. It is in vaccuo so that ambient temperature has little effect on it, only the current through it.
If there were end caps fitted to it that would seem to make sense. But I have just studied it with a more powerful eye glass and it dosen't look like the ultra thin wire goes through the molten sealed ends of the glass tube. I can clearly see that one end only reaches to within 15mm of the end, the other end looks to be touching the inside edge of the molten glass but not passing through.
Re: bag of bits
Post by crackle » Tue Mar 03, 2015 4:22 pm
Just checked the volt drop and the CV8261 is 0.54v. There is a single other diode in a can which looks like an AC128 package but painted black with an arrow on it together with the markings CV5099, this measures 0.72v, so does that make it germanium and the first diode is silicon.
Re: bag of bits
Post by crackle » Tue Mar 03, 2015 4:46 pm
ppppenguin wrote:You've measured the forward voltage drop of the propective zener. It will look like an ordinary diode. For a zener you need to find the reverse breakdown voltage.
I have just tried again with 100v supply and 8.2k resistor and there is no sign of any zener action, I measure 0.6v one way round and if diode is reversed I get 100v.
Re: bag of bits
Post by Michael Watterson » Tue Mar 03, 2015 4:52 pm
There ARE thermistors mounted like that. To keep out damp. It's less common than a thermistor in a point of a glass tube.
Re: bag of bits
Post by Stockden » Tue Mar 03, 2015 5:00 pm
According to the "CV Register of Electronic valves 1963" (here: http://www.tubecollector.org/cv/1963/) CV 8261 is a "semiconductor rectifier" and is equivalent to ZS32B. A web search for ZS32B suggests that's a 600V 1A device (or, to be precise, ZS32B can be replaced by a 600V 1A device).
CV5099 is also described as a rectifier and is equivalent to ZS22 and CV4078
Hugh
Re: bag of bits
Post by crackle » Tue Mar 03, 2015 5:23 pm
Hi Hugh
Thanks that is useful to know.
Re: bag of bits
Post by Terrykc » Tue Mar 03, 2015 5:56 pm
Crackle wrote:... The black resistor is 499k (light reflection makes it look like 429) obviously 500k was not precise enough for the circuit designers ...
Sorry, Mike. Wrong answer!
Remember this?
It contains all the values that the average VRAT is likely to meet and shows how the values dovetail together as the tolerances get tighter.
However, some people need even tighter tolerances and simply adding extra values into the left hand column would give a range which wouldn't quite blend together so neatly, so the ranges had to be tweaked slightly for a better fit.
If we go up a range further, we get these values:
E48 Range
1.001.051.101.151.211.27
1.331.401.471.541.621.69
1.781.871.962.052.152.26
2.372.492.612.742.873.01
3.163.323.483.653.834.02
4.224.424.644.875.115.36
5.625.906.196.496.817.15
7.507.878.258.669.099.53
Still not enough for your new resistor, so we need to go up yet another range!
E96 Range
1.001.021.051.071.101.13
1.151.181.211.241.271.30
1.331.371.401.431.471.50
1.541.581.621.651.691.74
1.781.821.871.911.962.00
2.052.102.162.212.262.32
2.372.432.492.552.612.67
2.742.802.872.943.013.09
3.163.243.323.403.483.57
3.653.743.833.924.024.12
4.224.324.424.534.644.75
4.874.995.115.235.365.49
5.625.765.906.046.196.34
6.496.656.816.987.157.32
7.507.687.878.068.258.45
8.668.879.099.319.539.76
... and there is 4.99 (and decade multiples!) for you ...!
