It is currently Tue Mar 20, 2018 10:51 am
Small timing pulleys and belts
Post by Amrad » Tue Sep 22, 2015 8:01 pm
I'm looking for some small timing pulleys and belts, preferably ones that use a 3mm wide belt, the smallest I've found use 6mm belts. Does anyone know of a source of any that use 3mm belts? Thanks.
Re: Small timing pulleys and belts
Post by crackle » Tue Sep 22, 2015 8:48 pm
3mm belts are almost rubber bands. I have seen similar used as a drive belt in reel to reel tape recorder, and Meccano.
Knowing the size of the pulleys you need and what you will use them for may help someone come up with a solution.
