It is currently Sun Feb 25, 2018 8:16 pm
Does Anyone Recognise This Connector Cable?
Post by peter scott » Sat Feb 13, 2016 6:59 pm
IMAG0644 (Small).jpg (25.03 KiB) Viewed 1501 times
Thanks,
Re: Does Anyone Recognise This Connector Cable?
Post by Jamie » Sat Feb 13, 2016 7:36 pm
There were lots of connectors in the 50s and 40s similar to this, all using randomly positioned pins. Different manufacturers used different plugs for their sets. All I can say about it sorry if that's no use. Could be military related though looking at the cloth cable and general bulkiness of the connector body itself?
Post by peter scott » Sun Feb 14, 2016 10:39 am
Thanks for replying Jamie. I suspect it belongs to the 30s/40s era and domestic rather than military. Probably connecting HT and LT between separate chassis.
Post by Briancuff » Sun Feb 14, 2016 10:57 am
Hi Peter.
I think you're right about domestic - have a look at the Baird T18 data. baird use what seems to be an identical connector in their pre-war range of teles!
Post by Cathovisor » Sun Feb 14, 2016 11:44 am
That would make it a Carr connector if it is.
Post by peter scott » Sun Feb 14, 2016 12:54 pm
Thanks Cath and Brian, I have some schematics for the T18 that show a rectangular 6 pin connector used in various places. I haven't found any photos as such. My one has a seventh pin the same form as the other six but I suspect it's just there for registration as it doesn't appear connected and I'm unable to open up the plugs. I tried web searching for Carr but the nearest I got was Carr-Lane although nothing similar.
Looking closer at the Baird connector the 6 pin grouping is similar but it appears to use a group of 4 smaller diameter pins in a square along with 2 larger diameter pins. The right era and very similar but not the same. Good suggestion though.
Thanks
Post by Briancuff » Sun Feb 14, 2016 1:41 pm
Here are a couple of T18 pictures thanks to Trevor, Peter. If you ask me, they're the same connectors as you have. The 7th pin, I assume, is for orientation purposes. Waddya think?
Post by peter scott » Sun Feb 14, 2016 2:08 pm
Hi Brian,
Looks spot-on!
I'm guessing this is TNC Trevor.
I'll PM him and tell him you just won him a cable if he wants it :aad
The outer shells in the photos are rather different.
Thanks,
Post by Briancuff » Sun Feb 14, 2016 2:53 pm
I'm sure he'll be happy with that, Peter!
