It is currently Mon Jul 23, 2018 2:59 am
Smoke from electronic gubbins.
Post by colly0410 » Fri May 20, 2016 11:10 am
Been reading the Wikipedia entry on 'Post hoc ergo propter hoc'. It says "after smoke comes out of an electronic component, it no longer works. therefore the 'smoke was magic', & made the component work." It sort of makes sense, but of course we all know it doesn't.. :)
Re: Smoke from electronic gubbins.
Post by Cathovisor » Fri May 20, 2016 1:17 pm
I think most of us know the old adage that all circuits run on smoke. If the smoke escapes, the circuit ceases to work.
See also the broadcast rule: the amount of aggravation a circuit causes is inversely proportional to its bandwidth...
Post by occiput » Fri May 20, 2016 1:49 pm
Also, blue light has a beneficial effect on electronics.
Faults only appear when the red lights come on. :aai
Post by Pamphonica » Fri May 20, 2016 6:09 pm
And the services adage on setting up transmitters:
"Tune for minimum smoke"
Jeremy
Post by Herald1360 » Sat May 28, 2016 5:31 pm
I always thought that was "Tune for maximum smoke"- on the basis that it was the load/atu/aerial which was smoking.
A good ATU should be able to match anything from wooden legs to damp string.
Post by Pamphonica » Sat May 28, 2016 7:54 pm
Yes, I think you are right! My memory of that adage is 45 years old.
I think we just tuned for max apparent power, never mind the fine detail.
Jeremy
Post by Wolfie » Sat May 28, 2016 7:56 pm
You can buy some more to restore operation.. this variety is for mobile applications only..
I make no claims about the effectiveness of the product, so if it doesn't work, sue Lucas not me..
Post by Dr Wobble » Mon May 30, 2016 10:36 am
Musicians used magic smoke to make records, I think they blew it into the mixing desk. Maybe to replace the magic smoke that had escaped? I've tried this with broken amplifiers. It didn't fix the amp, but I felt a whole lot better afterwards.
Andy.
Post by Herald1360 » Mon May 30, 2016 11:12 pm
Are you sure they didn't just inhale it themselves? :bba
