It is currently Thu Jul 19, 2018 2:59 am
What soldering iron/station do you use?
Weller
20
45%
Metcal
6
14%
Antex
10
23%
Ungar
0
No votes
Henley-Solon
2
5%
Litesold
1
2%
JBC
0
No votes
Gas Stove
0
No votes
Match (as in; you're MacGuyver)
0
No votes
Other
5
11%
Total votes : 44
Post by tunneldiode » Wed Sep 07, 2011 1:46 pm
You can pick more than one.
Just for fun.  :D
I don't think I've missed any brands!?!?
Post by Joe » Wed Sep 07, 2011 2:18 pm
I've also got a Portasol gas job.
- Joe
Post by Andrewausfa » Wed Sep 07, 2011 2:30 pm
Maplin? I bought a useable station from them.
Andrew
Post by Michael Watterson » Wed Sep 07, 2011 2:36 pm
You missed "other: Temperature controlled" and "other: Fixed"
I suspect my cheap temp controlled Iron of being a cheap fixed one on a lamp dimmer.
I have a Lidl solder gun (to weld plastic :) ). It's not hot enough to solder tinned chassis plates.
I've two dead Antex.
I have a Lidl paint stripper gun that works good to take off SM parts. :D
I've 2 or 3 small gas torches with soldering adaptors.
For serious Microwave work ;D a Camping Gaz blow torch.
Post by neil1974 » Wed Sep 07, 2011 6:30 pm
Ive got a few different irons. a 15w antex which is the better of the low wattage ones i have. an instant heat weller one which i now have tips for again thanks to Trevor. and a maplin variable temperature one that i had to resolder some connections in because they had very little solder on them  :shock: . and a couple of cheap chinese irons that i bought on the offchance they were ok and surprisingly they are. cheers neil.
Post by Steve P. » Wed Sep 07, 2011 6:57 pm
Well I have a Metcal and a couple of others, both Antex and one is temperature controlled.
Steve P.
Post by tunneldiode » Wed Sep 07, 2011 7:08 pm
Hmmmm.........I wasn't sure if I should have included an 'other' option; perhaps one of the Mods would be kind enough..............
Post by Ian E G7OLT » Thu Sep 08, 2011 9:32 am
My temperature controlled soldering 'station' came from CPC.
It's a model SL-20 made by 'Solomon' (whoever they are).
Post by tunneldiode » Wed Sep 14, 2011 4:53 pm
No Macgyvers yet then?
