It is currently Wed Jul 18, 2018 12:01 pm
capacitor and avo tester on ebay
Post by freya » Tue Sep 13, 2011 10:55 am
http://www.ebay.co.uk/itm/Comprehensive ... 3a6a41867a
its not mine but its in a nice box as well !
steve
Post by crustytv » Tue Sep 13, 2011 11:12 am
Joe:3119 wrote: heater volts are 2V so it wouldn't be any good for 1.5V battery valves.
- Joe
Hi Joe,
Not true, I have this model of tester, the heater extension unit allows you to select multiple heaters ranges by switching between the main panel and the extn unit giving you a range between 1.1V to 117V for heaters. Quite a good little tester, for testing gm and emission (bad/indiff/good)
I have tested battery valves, as well as some TV valves with honking great heater voltages.
My tester shown in post #2 http://vintagetvandradio.myfreeforum.org/about435.html
Post by freya » Tue Sep 13, 2011 11:13 am
:D
Post by crustytv » Tue Sep 13, 2011 11:27 am
This was AVO's first tester and it came out in the 1930's mine is 1947.
Over the years due to the MKI, MKII & MKIII CT160  etc all leaping to totally ridiculous figures (anywhere between £500  - £1000) the two panel has been dragged along for the ride.
I've seen them fetch as little as £50 and as much as £250, mostly around the £120-£150 for a good one, condition as usual dictates. Which makes it the cheapest tester to get after USA testers.
The hunts bridge is the early one the CRB. I have the CRB 3 (the sloping panel unit) and is constantly used, mainly as my Leakage tester. I have manuals for all if required.
Post by freya » Tue Sep 13, 2011 2:13 pm
it can test 1.4 volt series.
filament voltage to 10 volts
valve holder panel switch to 7 position
This is diffrent if the filament voltage extension box is used.
Post by crustytv » Tue Sep 13, 2011 2:17 pm
Nice one Steve, yes I forgot about the divide by 7 switch.
