It was a two-stage circuit but was advised to only build the single stage version to start with to ensure I stayed inside the pantry
Murphyv310 wrote:Hi.
The transmitter works with just about anything from a EF80 to 6V6 or even an 807. Its a real junk box project. Im going to do another with an EH90 & EF91.
Murphyv310 wrote:How about a minimalistic FM radio project?
Two Acorn valves and a super regen circuit springs to mind!
Till Eulenspiegel wrote:From the Radiomuseum: http://www.radiomuseum.org/r/schaub_pirol_56gwu.html
The UEL71:
http://www.radiomuseum.org/tubes/tube_uel71.html
I can't see how this set was ever any good.
Terrykc wrote:The UEL71 is unusual - even the number is wrong! - a signal tetrode and output pentode in one bottle on a Loctal base which should really be numbered in the 20 - 29 range!
Murphyv310 wrote:The Twin Acorn FM receiver is a PW design, I've the copy somewhere.
I built it with one valve (super-regen stage) and it worked well enough. With the RF amp it would work very well and stop the interference that these super-regens produce.
