It is currently Sun Jul 22, 2018 6:05 am
Making your own battery connectors for PP batteries
Post by Mike C » Fri Mar 01, 2013 1:37 pm
If you ever have a radio that someone has removed the original connectors you can make these easy by using battery tops, simply hack a PP battery apart to remove the top and you can do this with the PP9 to as well as a PP7 and 6. Its cheaper than buying them and if you have any dead batteries that are modern then this is a good use for these items.
Battery hack to obtain the top for connector use.
bth_DSCF4423_zps1ba1f49c copy.jpg (7.57 KiB) Viewed 911 times
