It is currently Mon Jul 23, 2018 4:54 pm
PP4 old kind
PP4 old kind
Post by Michael Watterson » Sat Mar 09, 2013 11:50 pm
There were two kinds of PP4. The original had almost x2 capacity of the PP3 as it was square cross-section, if the layer cells filled the box.
Later they made it round.
An alkaline PP3 will not fit in a sensibly made cylindrical PP4 as the width is too close to diameter. But it will fit in a square cross section PP4.
Only 5 AAA cells fit in the round PP4, but you can fit 6 x AAA (without a holder, so a custom holder or soldering needed) in the square version.
A PP3 will fit in the square one too. But best is to use the Alkaline PP3 and open it. (not all Alkaline makes are welded AAAA cells, which is what is needed, some are held in place by case.
6LR61 = 6 off AAAA size Alkaline cells = IEC LR61 cells
6F22 = 6 off Zinc Layer cells = IEC F22 cells
(Though not all Alkaline PP3 are exactly the same size!)
Compared are PP3 Zinc layer battery (6F23), AAAA (or similar) cells from Alkaline PP3 (6LR61), an AAA cell and an N or Lady cell (1.5V, similar size 3V lithium and 12V alkaline exist!). The N cell is too long to stack two in length and fatter than AAA, so no help at all.
Best is to open the Alkaline PP3 and cut the connector insulator in half, and cut the negative connector strip in half. Add a wire and double sided sticky foam pad to put the connector on the bottom.
It may then fit in the round case, but not if the wall is decent.
It fits easily in the squared case:
Compared to the Battery Valve boxes I have been making, this is like a battery for a dolls house!
Here it is full size! (300dpi, print so when folded it is 50mm high, each side just over 25mm, just under 1").
Fold the inner most tabs at about 47mm to 48mm spacing depending on card, as you have 3 layers of card on top and bottom!
Either print on 160mm card direct or 90gm paper and "Pritt" stick or spray mount to cereal box card.
Regard this is a prototype as I don't have a radio that uses PP4.
Pity the square version was replaced by round and that we only have the PP3, it would be nice to have 9V alkaline that was essentially 6 x AAA cells rather than the 6LR61 Alkaline as it's only 60% improvement on layer PP3 and only long life in smoke detectors.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 12:23 am
Actually looking here
viewtopic.php?f=48&t=4446
Does the PP4 use the larger Snaps like on a PP9? not a problem as you can buy those. Cut a PP9 connector up if this is the case.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 10:10 am
Adjusting for perspective from the brochure:
I think the PP3 fits well diagonally in the squarer PP4 case (I tested on the one I made) and enough extra height to only just fit a PP9 sized snap top and bottom wired to PP3 connector. A 6F22 (PP3 Layer cell) is about 450mAH and a 6LR61 (PP3 Alkaline with 6 off AAAA like cells) is about 590mAH, so based on volume the Alkaline PP3 gives closer to original PP4 capacity which must have been about 700mAH to 800mAH?
A PP9 is about 5000mAH at low drain (Perhaps 3500mAH at high drain) and a PP7 maybe about 2000mAH at low drain. I use 6 x Alkaline AAA in a PP7 (about 1100mAH) and 6 x AA in a PP9 (about 2700mAH). Certainly if you soldered there is space for 12 x AA in a PP9 case.
So I will see if I can do an Octagonal PP4 case as compromise between original slightly rounded case and later cylindrical case. It can then use the round PP4 label rather than my fake square case PP4 label.
Re: PP4 old kind
Post by Mike C » Sun Mar 10, 2013 11:08 am
Great work there Michael, I may give this a go and if it works I will attach the original connectors to my Sky Personal as I still have these. Space is very tight in the battery compartment so may try AAA cells. I have never taken a PP4 apart as I only have one example so I think the layer cells in mine will be round as my battery is a round metal clad.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 11:28 am
AAA cells will fit in an octagonal or square case, but you need to solder them. The insides of the Alkaline PP3 (AAAA cells already joined) 6LR61 is easier as AAAA are smaller than AAA.
I have the Octagonal pack with round pack label nearly done. Some geometry involved :)
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 12:03 pm
The 6 off AAA don't fit in the Octagonal-ish version, but it's only slightly more angular than the very rounded corner original version and also than the later cylindrical version. The round version label works well as it's not a regular octagon, but imagine a square with four corners cut to give the cut off bits about 1/2 of new flat sides.
I will tidy it up and publish.
Re: PP4 old kind
Post by Mike C » Sun Mar 10, 2013 12:06 pm
For me the round version may be better, The terminals I can get of a dead PP9.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 12:13 pm
The round version only takes the naked AAAA (4 As not AAA), and very tight. I think the Octagonal version is best compromise. If you squint it's round :) it will take PP3 in case or the 6 off AAAA out of Alkaline PP3.
Also the ends on the octagonal version are attached to the longer faces, and one end can be left unglued with tabs (You'll see the picture soon). The ends on the round version are much more awkward to attach and can't hinge :(
Re: PP4 old kind
Post by Mike C » Sun Mar 10, 2013 12:17 pm
Some of the early 996 lantern batteries had those beveled corners to, A PP3 would be better and easy to work with but it may make the battery bigger so it may just fit even though its a tight squeeze. You can still buy PP4 cells but there not cheap. This size as also used in a Ferguson transistor set to as well as some test meters.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 1:46 pm
Here is "nearly" round Octagonal version.
Print 300dpi and 50mm high when folded (unfolded image height 10cm 100mm, about 3.9").
Stick on to cereal box and cut out.
Note that tab 2 & 3 and matching ones on top must fold to give LESS height than folding Tab 4 and its matching top tab, which in turn fold slightly shorter than the coloured ends.
The top tabs are designed for a push fit so the clear top with cut out square for connector needs the side tabs folded in closer (you can see inset).
A PP3 still in the case should fit perfectly with narrow faces exactly filling a pair of longer flats.
Mistake on Octal PP4
Post by Michael Watterson » Sun Mar 10, 2013 3:18 pm
You need to cut off the two small tabs/tags on top edge as they are in the way.
The tabs, top and bottom may need cut just inside the black lines.
Use a blue felt tip pen or gel pen to colour any raw card/paper edges.
Optionally 3 coats of spray varnish or one layer of clear parcel tape around the body.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 4:40 pm
I made up connectors, and even taking the PP3 connector apart and putting a thin insulating shim under the minimal "naked" PP9 connector it's a couple of mm too long.
Using 6 off "AAAA" out of insides of Alkaline PP3 (6LR61 type) is no problem at all for height. The Kodak brand Alkaline PP3/6LR61 is too wide and distorts the Replica case slightly. All the other brands I've tried are OK.
Conclusion: The "AAAA" from a PP3 is best solution (not AAA) or if the battery compartment is large enough make the print out 3mm higher.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 10, 2013 5:06 pm
Well, if you trim the plastic off entirely on one side of the two PP3 connectors and bend up two opposite edges of the PP9 + terminal it's possible to get the lid folded in. Bulges a little, but sort of works and easier to refill (just plug in new PP3) than the better fitting AAAA innards solution.
Re: PP4 old kind
Post by Michael Watterson » Sun Mar 17, 2013 8:33 pm
The layout I have fits fine with inside of an Alkaline PP3, (6 off AAAA cells, not AAA) but is a bit short for a PP3 with a plug:
PP3 with a PP3 connector and PP9 studs on the PP4
Re: PP4 old kind
Post by Refugee » Thu Mar 21, 2013 1:53 am
Have PP3s shrunk since the 1980s?
If I can remember rightly I abandoned fitting a PP3 connector because the battery would not fit in the case by a very small margin. With the can off a PP3 might well fit with an adapter.
If the cells from an alkaline PP3 will re-stuff into it this could be the way to go however I will need a new snap for the negative end :(
This is what I want it for.
viewtopic.php?f=15&t=4608
The leaky battery does have a good label on one side while the other side is a bit rusty.
Re: PP4 old kind
Post by Mike C » Thu Mar 21, 2013 10:31 am
I have never taken this size apart but I suspect it wont be easy unlike a metal clad PP9, The seal at the side is folded over and the case will loose its shape very easy, it will be like taking a metal PP3 apart which I tried on a dead Panasonic and the case just bends, that said you may just need to pick apart both ends but if the cells are stuck because of leakage it will be difficult without spoiling the case as its so fiddly. I would think the layer cells are round inside but not sure as I have never taken one apart as this battery is rare as I only have one of and its the same as yours.
PP3 Size
Post by Michael Watterson » Thu Mar 21, 2013 10:54 am
There are at least 3 sizes of PP3 unfortunately,
The smallest are some Layer types. About 25mm or slightly less wide
Medium size are some Layer types and many Alkaline. Lidl and Aldi Alkaline PP3 do fit a B126 and virtually all Layer types do. Polariod and Sony 6F22 layer type are this size. About 25.5mm wide.
Largest are some Alkaline, and a few layer type (but the internal layer biscuits same size as Medium ones I think). The Kodak Alkaline don't fit a B126 box or snap together in a chain as they are wider and thicker. Possibly up to 27.5mm wide
Alkaline 6LR61 = 6 off AAAA size Alkaline cells = IEC LR61 cells
Layer 6F22 = 6 off Zinc Layer cells = IEC F22 cells
Some "vintage" things will only easily take the smallest size and will not take Kodak size 6LR61 Alkaline. Note that "AAAA" in Alkaline 6LR61 are slightly shorter than true AAAA dimensions.
F22 = IEC designation for one biscuit or layer that fits PP3
LR61 = IEC designation for an AAAA Alkaline cell (L always means Alkaline, R means Round and 61 is type)
I think you have to open the Alkaline 6LR61 PP3 and cut off the existing PP3 connector and solder round PP9 snap to top and wire 2nd PP9 rosette snap to the bottom. Use a shim of marge tub plastic or similar for insulation.
Revised Layout, make a compromise 25mm x 49mm approx (excluding connectors). Measure depth/height required by naked AAAA cell from PP3 6LR61 Alkaline and 2 x mount but not actual stud of the PP9 style snap connectors.
Note inner Top and Bottom flaps fold to shorter length (by card thickness x 2) than outer flaps. The two small bottom tabs shorter still.
Finally wrap the pack in one layer of clear parcel tape or a few coats of Acrylic varnish/Lacquer (never the water based kind!).
Re: PP4 old kind
Post by Refugee » Mon Sep 16, 2013 1:29 pm
I have discovered that a link had broken in a post I posted in this thread some time ago.
Here is the repaired link.
