It is currently Mon Jul 23, 2018 4:48 pm
6 Volt motor bike battery.
Post by malcscott » Tue Oct 29, 2013 1:12 pm
Hi, my 1957 BSA Bantam 175 uses a 6 volt lead/acid battery. This battery is knackerd and i was thinking about re-stuffing it with ni-cad cells. Any ideas about this method?? Malc :aaq
Re: 6 Volt motor bike battery.
Post by Refugee » Tue Oct 29, 2013 2:14 pm
The motorbike will have a charging circuit to suit lead acid construction batteries.
A lot of modification will be required to use other battery types.
Motorbike batteries should not be that difficult to obtain.
Post by Michael Watterson » Tue Oct 29, 2013 3:15 pm
You can still buy 6V Lead Acid bike batteries. Plenty of vendors, both regular and eBay.
Both the SLA 6V (more expensive anyway) and NiMH (you would want five) would be short lived. The voltage doesn't rise sharply on NiMH to switch to low trickle charge.
SLA rarely last long in a Motorbike as they get discharged too deep and charged too quickly.
Post by Wolfie » Tue Oct 29, 2013 7:37 pm
Nicads are a nono for Vehicle charging systems without some modification, but there is a good range of SLA batteries on the market designed for vehicle use.
Post by malcscott » Wed Oct 30, 2013 1:18 am
What is an SLA battery? :aaq
Post by crustytv » Wed Oct 30, 2013 2:00 am
Post by Michael Watterson » Wed Oct 30, 2013 11:28 am
The "motive" SLA are usually only suitable for Electric motors and separate charger, not the charging in a Motor bike. They are different design to the SLA used in Burgler Alarms and Emergency lights etc.
There are actually 3 kinds of SLA, 2 x gel and 1 x mat and as best as I can figure both the Gel kind and Mat Kind originated in 1932 for portable valve radios! By 1937 all new design portables used sealed gel cells in a plastic case, but likely different Gel and Plastic to that used today.
My 1929 McMichael Suitcase has acid burns on inside of case as it used a conventional glass cased "Wet" type lead acid pretty much like one cell of a 1950s motorbike battery (which is 3 cells).
The "Wet" type cells are still best performance & life which is why they are still used for cars, trucks and road-bikes (Racing bikes may be more exotic on batteries).
Both 6V Bike and even 6V car batteries are still made and available.
