It is currently Sun Jan 21, 2018 1:11 pm
Mystery "Radio"
Mystery "Radio"
Post by Briancuff » Mon Aug 20, 2012 7:46 pm
Hi all
An auction house is offering this item as a "Military Radio Set". It looks more like a grid dip meter or similar. Does anyone know exactly what it is? I see that there is a verneer on the units dial so it must be for measuring - or must it?
Re: Mystery "Radio"
Post by crustytv » Mon Aug 20, 2012 7:50 pm
I took the liberty of enhancing so others may find it easier to help.
Re: Mystery "Radio"
Post by turretslug » Mon Aug 20, 2012 8:59 pm
I believe it's a BC221 frequency meter, of US manufacture circa WWII vintage- as with much of this stuff, must have cost a fortune to make, but singularly business-like in presentation.
Colin.
Re: Mystery "Radio"
Post by Michael Watterson » Mon Aug 20, 2012 9:26 pm
Good stab Brian, as part of the feature of most dip meters (grid or gate!) is to turn off the oscillator and use it as a "wavemeter" (basically a calibrated crystal set!). Which is all you had till frequency counters could do MHz rather than a few 10s of Kilohertz.
You can use it as a very deluxe crystal radio :)
Re: Mystery "Radio"
Post by GlowingAnode » Mon Aug 20, 2012 10:31 pm
Definitely a BC221 super-het frequency meter.
Recognised it from the first upside-down partial shot!
And I bet the range switch is seized up.
Rob.
Re: Mystery "Radio"
Post by Briancuff » Tue Aug 21, 2012 8:56 am
I assume then, the there were calibration charts to go with the kit which translated dial readings to frequency. When you say "superhet frequency meter", Rob, does this mean that it has a reasonable amount of electronics inside?
Re: Mystery "Radio"
Post by Michael Watterson » Tue Aug 21, 2012 9:05 am
Yes,
Certainly much more than a simple wavemeter.
Did you check BAMA for the manuals?
Re: Mystery "Radio"
Post by GlowingAnode » Tue Aug 21, 2012 12:36 pm
Brianc wrote:I assume then, the there were calibration charts to go with the kit which translated dial readings to frequency. When you say "superhet frequency meter", Rob, does this mean that it has a reasonable amount of electronics inside?
Yes, you're absolutely right Brian.
Without the calibrated charts, the meter is pretty much useless.
Internally there's very little, two or three valves (6sk7?) and a (1Mc/s?) octal based crystal.
A popular mod in the 60's was to use these as a VFO for a transmitter, good stability after 20 mins or so warmup. The tuning mechanism is exceptionally well made, as is the whole of the meter. Unfortunately to get to the band switch, which seem to have a habit of rusting up solid, requires dismantling virtually the entire instrument. The knobs have a special splined Allen key, that should live inside in a little clip.
Rob.
Re: Mystery "Radio"
Post by Michael Watterson » Tue Aug 21, 2012 5:20 pm
I presume with an accurate modern generator you could make charts?
Re: Mystery "Radio"
Post by GlowingAnode » Tue Aug 21, 2012 9:04 pm
Yes, indeed you could, a tedious process as the book contains several thousand calibration points.
Interesting related article here; http://jproc.ca/ve3fab/bc221.html
Rob.
Users browsing this forum: Bing [Bot] and 0 guests
