It is currently Mon Jul 23, 2018 12:35 pm
STC Coupling unit Ae
Post by niall » Sat Jun 07, 2014 4:33 pm
Picked this up at the Livingston mini rally for a pound.
Some sort of remote aerial tuner. First thoughts were the connectors are very Larkspur, but it's painted black. Some research on line suggests it is aircraft equipment. I suspect from the size it's VHF and quite low power, but the aerial connections are for open wire, not coax. Inside there is a powered rotary switch which switches some capacitors and a small coil.
Manufacturer is STC. Front panel markings:
(STC badge)
COUPLING UNIT AE
216-LRU-29A
SER NO. B15
WT 2lbs 2ozs
5985-99-948-7140
I have looked in the usual places like VMARS but no hits on the model no. or NSN.
Anyone have any info or a circuit?
Re: STC Coupling unit Ae
Post by Beamcurrent » Sat Jun 07, 2014 9:38 pm
Hi
It is probably from the STC "STR xx" series of aircraft radios.
I have some bits of the STR18 series awaiting restoration, when I can find the time! My ATU looks like this:- 24-LRU-52b Not quite the same number as you quote, Have you a picture?
Anyway a real bargain at a pound!
Post by niall » Sun Jun 08, 2014 12:02 pm
Hi Brian,
Not much to see, it's a plain black box about 165mm x 80mm x 75mm deep with a mounting flange.
One end has an RF socket, old 75 ohm type with screwed retaining ring, Plessey type 104 2 way socket for 28VDC, type 104 12 way for control. Other end has an earth terminal and insulated aerial terminal.
I have traced out the circuit. There are two switch wafers on the Ledex shaft apart from the Ledex control wafer.
Switch positions are:
1 Straight through
2 series cap, shunt coil top connection
3 series cap, shunt coil top
4 straight through.
5 series cap, shunt coil tap
6 series cap, shunt coil tap.
From the component sizes, I'm thinking this is probably a matching unit for airband VHF.
