It is currently Mon Nov 20, 2017 10:42 am
Henry Moseley
For discussions about technology and people in technology.
Henry Moseley
Post by turretslug » Mon Aug 03, 2015 11:05 am
Talented British physicist Henry Moseley, killed at Gallipoli- as with Alan Blumlein, what might have been.... Programme on BBC World Service this evening at 1832 and 2332 and (insomniacs) 0432 (all GMT, add an hour for BST!);
http://www.bbc.co.uk/programmes/p02y4hfy
Re: Henry Moseley
Post by Valvebloke » Mon Aug 03, 2015 4:10 pm
As a physics undergraduate and then a doctoral student I remember that one of Moseley's original graphs of the relationship between atomic number and X-ray frequency was displayed on the main staircase of the building I worked in. The department was rightly very proud of it. One of the things which struck me about it was how large it was - somewhere between A1 and A0 as I recall !
I'm just about old enough to remember physical graph paper being used 'in anger' to interpret experimental results. Our stores kept quite a range. As well as the usual linear stuff (which we had printed from our own plates, to save money) you could also get various types of Log-Lin and Log-Log if you needed to determine power-law relations between data sets. If your data had very low error bars then bigger bits of paper could actually give you higher precision !
VB
Re: Henry Moseley
Post by Cathovisor » Mon Aug 03, 2015 4:54 pm
Yep - I remember when such graph paper was held in the office when I started my life in television...
Re: Henry Moseley
Post by Hartley118 » Tue Sep 15, 2015 7:03 pm
I do still have various pads of graph paper of various scales which I use from time to time.
There's little substitute for manual graph plotting - interacting directly with the data and seeing the plot evolve means that spurious results can be picked up more quickly.
Martin
Re: Henry Moseley
Post by peter scott » Thu Nov 26, 2015 1:47 pm
The lab where I worked used to keep a good selection of loglog, and loglin in various numbers of decades. Nice looking stuff.
Re: Henry Moseley
Post by Ed Dinning » Thu Nov 26, 2015 9:44 pm
It was expensive stuff, latterly I used to cheat by using the full sized Chartwell? samples book and a photocopier.
Re: Henry Moseley
Post by Terrykc » Fri Nov 27, 2015 12:48 am
These days, of course, you can print your own without the random distortions that your photocopier might have introduced!
For example:
http://www.physics.utah.edu/~gernot/ele ... _paper.htm
Return to Technology & People
Users browsing this forum: Bing [Bot] and 1 guest
