It is currently Thu Jul 19, 2018 5:56 pm
A Marconi 702 Mirror Lid
Re: A Marconi 702 Mirror Lid
Post by Katie Bush » Wed Aug 31, 2016 11:30 pm
Cheers, Brian, I'll see about acquiring some..... :aad
Post by Briancuff » Fri Sep 02, 2016 7:39 pm
After mending a toilet cistern (the manufacturers had changed the ball valve type an have not supplied a mod kit so I had to wing it), I got on with the 702 PSU. The picture shows the new tinplate 3 capacitor block box finished in primer. I will paint it dark grey tomorrow. The loom goes straight up to the Sync chassis termination panel and the green lead from one of the CRT connectors is the vision drive to the CRT grid.
Tomorrow I will concentrate on the underside and perhaps even finish it - then comes the TRF which is a whole new ballgame. At least it's easy to test but I'm not sure how to deal with its chassis yet - mask and paint as I sure ain't going to dismantle it like I did the other chassis :ccf :ccf .
Post by Briancuff » Sun Sep 04, 2016 7:30 pm
Well, the PSU chassis is now finished and will be tested tomorrow. The couple of pictures show the topside and underside. You'll note that I've put a bit of acrylic over the bleed chain tagboard on a temporary basis but I will modify it by lowering the tagboard as it is almost level with the chassis bottom. I will have to shorten the two spacers and fit the board under the brackets spotted to the chassis at the other end. I really don't like the idea of the tagboard at 5kV being so close to the cabinet bottom.
The colour balance is a bit off in this picture!
It's a pity that the EHT enclosure looks a bit crooked! I'll take it off and see if I can't sort it out.
Post by Cathovisor » Sun Sep 04, 2016 7:34 pm
It's looking very good, Brian... :aad
Post by Jac Janssen » Sun Sep 04, 2016 7:44 pm
Phenominal progress Brian!
Can't wait to see the complete working set.
Jac
Post by Jac Janssen » Sun Sep 04, 2016 8:05 pm
Brian,
On closer inspection, I'm missing C6 (1 µF/1500V on the focus voltage), and the accompanying wire to the screw/tag board.
Is that capacitor located now somewhere else in your set?
(I noticed a replacement on the dismantled power pack parts.
The original has been a green rectangular one. Not dissimilar to the 0.1+0.1µF, but a lot smaller.)
Jac
Post by Briancuff » Sun Sep 04, 2016 9:22 pm
You're absolutely right, Jac! The cap is missing at the moment as I am having to make one from scratch - I have already made a couple for other people! I was disapointed tofind the oval one in the set as it would be very difficult to re-stuff as it seems to be swaged together like a tin of beans as well as soldered so I decided to manufacture a completely new one.
There's no fooling the guys on this forum :) :)
Post by Rallycoordinator » Sun Sep 04, 2016 10:41 pm
The cable lacing of the replacement wiring loom looks very professional and certainly adds the finishing touch to your restoration. Looking forward to the next installment of this comprehensive account. :aad
Post by Briancuff » Mon Sep 05, 2016 10:36 pm
Thanks Mike. The lacing was a thing I learned when in the planning dept. of the BBC. I used to watch the wire-men at work and ask lots of questions!
Especially for Jac, I stayed up late this evening to finish the replica Focus supply smoothing cap for the 702. I had two abortive starts and ended up by adjusting the rip fence on my circular saw as I was trying to make a former for the cap but is was not coming out square. The cap inside is one of "Ask Jan"'s 1.0 mfd @ 1.5kV.
Sorry about the dark bit at the top. I have a rubber stamp and white pad to put the screened info on when the paint has hardened a bit more.
I try to make the terminals look as correct as possible.
Post by Jac Janssen » Tue Sep 06, 2016 7:32 am
This is very impressive Brian!
Virtually indistinguishable from the original! Mij first impressing seeing the photo was - hey - were did you find this NOS original capacitor!
I must say that I believe that this type of TCC capacitor in general is quite good.
In my 702, which was in an appalling state, both the 1µF and the 0.1+0.1µF capacitor were in good condition (after reforming gradually).
So it must have been a quick repair to replace the one in your set.
Jac
Post by Briancuff » Tue Sep 06, 2016 7:48 am
The Large cap (0.1 + 0.1) tested fine at 3kV so I decided to leave it be - here's hoping!
I had a rubber stamp made with the correct script for the focus cap (it's a pity that it's hidden) but it is very easy to mess the print up and then it could be a re-paint job so I modified a mini-drill press to do the job but there was so much lateral play that I had to scrap that idea!
Next is to fit the focus cap, try to straighten the EHT enclosure and get on with the TRF. That one will be a problem if I can't get the metalwork clean enough. No way will I dimantle that one - well, maybe just the tagboard :)
Post by Briancuff » Tue Sep 06, 2016 2:42 pm
The PSU is now officially finished. I have not put the text on the new cap as I can't find the box with the rubber stamps and inkpads in it so I decided to go ahead and install it anyway. Should I find the box in the near future, It is a very easy job to remove the cap provided that I have not installed the PSU back into the cabinet. I have a doctors appointment now so will stick it on the variac when I get back. Here are are a couple of pictures - one for Jac:
New cap without white text unfortunately.
EHT enclosure a bit tidier now.
Post by Cathovisor » Tue Sep 06, 2016 5:23 pm
Brianc wrote:I have not put the text on the new cap as I can't find the box with the rubber stamps and inkpads in it so I decided to go ahead and install it anyway.
Get Sarah to look for it :qq1
Post by Briancuff » Tue Sep 06, 2016 6:52 pm
That's the general plan, Mike!
I have now tested the PSU and there was a wiring error where I applied two neutrals to the EHT mains Xfmr so no EHT. A relatively easy fault to find. However, on rectifying the fault, smoke issued from under the chassis - one of the first two Rs in the EHT bleeder chain! The smoothing cap in the twin can had gone short circuit - the reservoir cap is OK (4.5kV off load with no smoother) but 'tother has gone short circuit so I will have to open the huge green beast and replace the caps (both as a precaution). I haven't repaired these caps before, only made replicas and of course, they're not the same as the factory made specimens! So instead of getting on with the TRF, I will be messing about with the 0.1mfd + 0.1mfd 5KV cap can which will probably end up with a re-spray. Such is life.
Post by Cathovisor » Tue Sep 06, 2016 6:57 pm
If that's the original EHT cap that's gone 'phut', I wouldn't have trusted it anyway if I'm honest.
Post by Briancuff » Tue Sep 06, 2016 7:12 pm
I stuck it on 3kV for a couple of hours and it was OK but, I suppose, the extra couple were enough to blow it out!
Post by Jac Janssen » Tue Sep 06, 2016 7:44 pm
Hi Brian,
I tested the 0.1+0.1 µF at 6kVDC (the maximum my power supply can supply).
After some time (I didn't make a note of how long it took), the leakage current was in the region of 20 µA per side.
This did not increase again after several hours, and a few days later it was the same.
Negligible compared to the current through the bleeder resistor chain.
Perhaps I am just lucky with the caps in my 702 - this was more than offset by the condition of the rest of the power pack.
This was how the power pack was when I bought the set:
702 wrak.jpg (62.65 KiB) Viewed 6971 times
To be honest, the good electrical condition of these large TCC capacitors was an unexpected result.
Jac
Post by Briancuff » Tue Sep 06, 2016 9:34 pm
Good heavens Jac, That PSU looks terrible! I assume that the set had been standing in water for some time! I assume that you rescued it by stripping and re-plating.
Just to round things off today, I put the TRF (Vision RX) chassis on the bench to see what had to be done for the restoration. It looks to be in pretty good condition with no rust and all components at least looking OK. In fact it looked so good that I thought that I would power it up using my bench PSU. 4VAC and 250VDC was duly applied - nothing. HT current about 30mA. I then switched 'scope to correct input and got 17Vp-p bars which is enough to drive the hexode CRT to full modulation! The bandwidth didn't look too good and the sensitivity pot is faulty but it's a very good start.
I'm not sure how to tackle the finishing of the chassis in this case. It's fairly complicated metalwork wise and I will not strip the electronics out in order to spray it as the RF side is much more likely to cause difficulties during disassembly and reassembly. There are two sets of screening cans - short solid copper ones beneath the valves and thin alloy ones for the valves themselves. I will spray the copper ones and polish the alloy ones but that leaves the chassis itself together with the bracketry. I think that I should take it apart as far as possible and then very carefully mask all the non-paint areas and spray it and the brackets.
But first, the EHT cap re-stuffing - but that is another day!
Post by Briancuff » Wed Sep 07, 2016 7:21 am
It's another day now so I should start on that wayward cap block - but wait a minute, isn't there an EHT interlock on the EMI MKI TVs? Yes there bl**dy is and who forgot? What a prat. I was lying in bed trying to get to sleep in spite of Steroids when it suddenly dawned on me - short circuit cap! They normally go leaky but not S/C and then I realised what a fool I was. I tested it this morning with the intelock defeated and got 4.8kV so all is well with the PSU chassis.
Post by crustytv » Wed Sep 07, 2016 7:58 am
Hi Brian,
Some of my best diagnostics or moments of inspiration have taken place when dozing off and even in dreams. Circuits faults going round and round in my head, armies of diodes, caps and transistors marching in my head. Then a possible solution presents itself, Its almost like lucid dreaming. Sometimes it drives me so nuts I just have to get up and go into the workshop to see if it works, I've been known to do that in the wee hours.
Glad your noodle doodlings sorted it for you, onwards and upwards dmm
Post by Jac Janssen » Wed Sep 07, 2016 8:23 am
That's tremendous progress again Brian!
I put in a 3mm screw in the shorting bar, on the "backside" (front-side of the cabinet) to keep the shorting bar "loaded".
Not a clear picture, but it should give you an idea:
2015-06-18 702 128 PP ak.jpg (4.42 KiB) Viewed 6920 times
The chassis was corroded through and through, and had become too weak to support the heavy transformers.
2015-05-07 702 64 power pack chassis.jpg (17.21 KiB) Viewed 6920 times
A great technical guy was prepared to make me a replica chassis, and he has done a fantastic job.
2015-09-09 702 431 PP nieuw chassis.jpg (8.81 KiB) Viewed 6920 times
The connector board also had become completely corroded and too weak to support the pull of the heavy wires. The connectors, or what was left of them, could not be saved due to the corrosion again. So I had to make a new one.
2015-05-21 702 97 PP conn.board nieuw-oud.jpg (24.56 KiB) Viewed 6920 times
As you see this is the early version, and differs from yours mainly in printed text/lines.
I would rather have kept the original chassis and connector board, but in this case I has no real choice.
Jac
Post by crustytv » Mon Sep 12, 2016 12:32 am
Part two of the story with Brian, continues here: https://www.radios-tv.co.uk/community/b ... on-part-2/
