It is currently Sat Jun 23, 2018 8:48 pm
Best bakelite polish?
Post by malcscott » Tue May 15, 2012 11:37 am
Hi, i have tried various kinds of stuff to polish bakelite. I find that bako-brite about the best. What do you think is the best to use? Cheers, Malc.
Re: Best bakelite polish?
Post by crustytv » Tue May 15, 2012 11:41 am
Same as you Malc, prior to that I used bees wax. Bako-brite is the dogs danglies when it comes to making a TV22 or DAC90 shine :thumbl:
Post by rob t » Tue May 15, 2012 12:03 pm
i agree Bako-brite every time allso found it good for removing cup rings from polished wood
rob t
Post by octal » Tue May 15, 2012 12:14 pm
Is that the same as Greygate No5 ?
Post by crustytv » Tue May 15, 2012 12:21 pm
yep
Post by octal » Tue May 15, 2012 12:32 pm
Thanks Chris.
Also ok for the Catalin, Ivory DAC90A I presume ?
Post by KeithW » Tue May 15, 2012 12:40 pm
I think the ivory will be urea-formaldehyde rather than Bakelite, a different chemical composition. Bakelite polish will be too abrasive. Try normal bees wax.
Keith
Post by Stitch » Tue May 15, 2012 12:50 pm
I haven't tried Bako-brite but did wonder what it was like. I do use Greygate Plastic Polish which is very good, but is this the same as No5, which is the same as Bako-brite??
I use brasso or T-cut first then polish with Greygate and finally a squirt of 'proper' furniture polish.
I've just finished a Philips 371 that has come up a treat :thumbl:
PS
I've just run out of Greygate, where's the best place to get it or Bako-brite? I think Radiophile sell Bako-brite.
Post by octal » Tue May 15, 2012 12:56 pm
KeithW wrote:I think the ivory will be urea-formaldehyde rather than Bakelite, a different chemical composition. Bakelite polish will be too abrasive. Try normal bees wax.
Keith
Ah, I thought the Ivory DAC90A was Catalin. Just looked up Urea Formaldehyde and it is described as having a hard skin, seems as hard as the Bakelite DAC's I have.
BTW, stitch, I bought 2 x 60 grm tubes of Greygate No5 off an ebay seller for £7 post free.
Post by KeithW » Tue May 15, 2012 1:00 pm
I'd be very careful, I've seen it used on an ivory coloured 1930's telephone and it dulled the existing surface :roll:
Keith
Post by octal » Tue May 15, 2012 1:12 pm
Appreciated, I will take care. First of all I need to remove a fair amount of nicotine deposit, yuk !
Post by KeithW » Tue May 15, 2012 1:15 pm
Apparently this is recommended for coloured plastics such as urea-formaldehyde, acrylics etc:
http://compare.ebay.co.uk/like/16035841 ... sbar&cbt=y
Keith
Post by Stitch » Tue May 15, 2012 1:21 pm
octal wrote:BTW, stitch, I bought 2 x 60 grm tubes of Greygate No5 off an ebay seller for £7 post free.
Thanks Octal, I've just ordered some ...
http://www.ebay.co.uk/itm/GREYGATE-BAKE ... _720wt_709
The 'plastic polish' seems to be more of a liquid so I'll give the paste a try.
Post by octal » Tue May 15, 2012 1:26 pm
Thats the one, good buy I thought :thumbr:
Post by malcscott » Wed May 16, 2012 8:59 am
Ive orderd 2x 60g Greygate paste. :thumbl:
Post by Alistair D » Wed May 16, 2012 3:06 pm
I have had great success using a Dremel type hand tool and a very soft felt end on disc. Turn the revs well down and a light touch. It even works a treat on the front of Avos. No polish required. Be careful about selecting the disc. Any of the hard felt ones will wear away the bakelite in no time.
Post by malcscott » Thu May 31, 2012 10:21 am
Hi, before i start using this Greygate paste, do i apply it with a damp or dry cloth? Cheers, Malc.
Post by crustytv » Thu May 31, 2012 10:30 am
dry and only a small amount is needed
Post by Paul_RK » Thu May 31, 2012 12:54 pm
octal wrote:Thanks Chris.
I've been happy with the results from Bake-O-Bryte on the three cream DAC90As here, also on a blue Masteradio Sandown Sapphire, but there's never any harm in seeing what happens with a small area inside or underneath the case before committing yourself. Catalin is a different kettle of fish altogether with an extremely fine and smooth surface in bright, often marbled or 'swirly' finishes which darken with time and exposure: catalin that was white when produced is a rich, deep butterscotch yellow now. I bought possibly the cheapest catalin radio to pass through eBay in recent years when a green case, left alone probably for decades, had come to look very much like common 'walnut' bakelite. Brasso was sufficient to restore that to a brilliant green and is generally as abrasive a cleaner as catalin ever needs.
Post by valvekits » Wed Aug 15, 2012 2:36 pm
After following this thread I purchased some Greygate No5
http://www.ebay.co.uk/itm/170890934793? ... 1439.l2649
I used it to polish some bakelite but also found it was very good at removing fine scratches out of perspex.
It really is lovely stuff and works a treat at polishing up chrome and other metals so I bought some more. :thumbl:
Eddie
Post by unclereggie » Mon Mar 18, 2013 9:44 am
Any idea where Bako-brite can be obtained from (UK) A quick search on google just threw up this thread! :lol:
Research seems to suggest that Greygate No 5 is the new brand name.
Post by crustytv » Mon Mar 18, 2013 10:28 am
Yep Greygate is the equiv see post #4 & #5 above :thumbl:
Post by Paul_RK » Mon Mar 18, 2013 3:59 pm
unclereggie wrote:Any idea where Bako-brite can be obtained from (UK) A quick search on google just threw up this thread! :lol:
The polish has been around for decades as Greygate No.5 - memory's telling me the GPO used it in quantity when restoring bakelite telephones. As I recall Bake-o-Bryte was Chas Miller's invention of a name for it when he began to offer it to radio enthusiasts. He's still selling it at £3.75 a tube inclusive of postage from The Radiophile's usual address.
